Activity › Forums › Apple Final Cut Pro Legacy › kona cards
kona cards
Posted by Salah Elfalahi on November 13, 2009 at 2:31 pmHi all’
Now i know that Kona cards (i intend to buy LHi to down convert HD to SD) will give me the best possible broadcast quality, but my question is; Do i need a deck with SDI input or i could do the conversion internally and then print the converted file to tape, and still have the best quality.
thanksSalah Elfalahi replied 16 years, 10 months ago 4 Members · 9 Replies -
Rafael Amador
November 13, 2009 at 3:05 pmHi Salash,
They supply a cable with Components, Composite and Audio connexions.https://www.aja.com/products/kona/kona-lhi.php
rafael
Salah Elfalahi
November 13, 2009 at 7:56 pmthanks Rafael
but I’m still not certain as my sony deck got firewire and component input and I’v read previously on this forum that a component will give me a very bad quality conversion, and thats why I need to know if possible to convert and export the HD file using Kona to the desktop and then import the SD file back to print to tape via firewire.
thanks
Does that make sense!! -
Shane Ross
November 13, 2009 at 9:29 pmCapture cards like the Kona don’t convert when you compress internally. They only convert when you capture or output.
Shane
Read my blog, Little Frog in High Def -
Rafael Amador
November 14, 2009 at 5:02 am[salah Elfalahi] “a component will give me a very bad quality conversion, “
This is not true at all.
Components have been the top standard for many years.
if your desk have FW and Components, is the best option to record with high quality.
Just play your HD and let the KONA downscale.
Rafael -
Salah Elfalahi
November 14, 2009 at 12:22 pmthanks again rafael
I’ve always wanted to buy one of kona cards but i thought only SDI input would give me better quality than compressor, but if component would do the same, then I’ll go for it.
thanks very much -
Gary Adcock
November 14, 2009 at 4:47 pm[Rafael Amador] “This is not true at all.
Components have been the top standard for many years. “I agree.
component video input and output will offer the OP the best quality possible.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Gary Adcock
November 14, 2009 at 4:49 pm[salah Elfalahi] “i thought only SDI input would give me better quality than compressor, but if component would do the same,”
HD/ SDI is the digital version of a Component Y’Cr’Cb’ signal with the addition of timecode, audio and metadata in one pipe.
gary adcock
Studio37
Salah Elfalahi
November 14, 2009 at 8:26 pmthanks gary for the very important informations.
really happy to hear that.
thanks for you all
