Activity Forums AJA Video Systems Kona card capture question
  • Kona card capture question
    Posted by Kurt Murphy on January 7, 2008 at 9:10 pm
    With Final Cut Studio (version 6.02) what system settings seem to work best with being able to work with After Effects rendered movies. The Kona people recommended using the Apple Prores 422 (HQ) (because we’ll use up space too quickly with uncompressed). The Kona recommended the prores because it was 10bit at PhotoJPEG file size.
    Also, is there a Prores codec that After Effects can output to? We hate having to render every AE file out in Final Cut.
    thanks,
    kurt murphy
    Jeremy Garchow replied 18 years, 7 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    January 7, 2008 at 11:07 pm
    Do you mean ProRes on a PC? No, you will have to use something else such as SheerVideo from bitjazz.
    If you are using AE on a Mac and have FCP installed on it, you can use ProRes on there no problems.
    Jeremy
  • Kurt Murphy
    January 10, 2008 at 2:18 pm
    Jeremy,
    Ah… But what if you DON’T have Final Cut on the system? We have it on two systems but not 2 others and we can’t open up their movies on the ones without.
    thanks,
    kurt
  • Jeremy Garchow
    January 10, 2008 at 4:52 pm
    ProRes is a codec like any other.
