Activity › Forums › Apple Final Cut Pro Legacy › Kona audio out and optical audio out
  • Kona audio out and optical audio out
    Posted by Eric Hansen on March 12, 2009 at 7:28 pm
    I’m on a Mac Pro with a Kona 3 card. i would like to monitor audio with the Kona 3 (via an AES to Analog converter) through my speakers, but also hook up a Behringer Ultra-Curve Pro with VU meters through the optical out of the Mac Pro. i don’t see an option in Final Cut to output audio to multiple outputs. is this possible?
    thanks
    e
    Sean Oneil replied 17 years, 6 months ago 2 Members · 1 Reply
  • Sean Oneil
    March 13, 2009 at 5:44 am
    No you can only pick one output. Even if you could do two, they wouldn’t be in sync with each other. Get a Behringer Ultramach Pro. With that you can output analog and optical from the same AES source.
    Sean
