Activity Forums AJA Video Systems Kona as a replacement for Cinewave -Questions
  • Kona as a replacement for Cinewave -Questions
    Posted by Michael Brassert on July 26, 2006 at 9:59 pm
    I have been happy with my Cinewave but it is time to move on. I need analog component in and out, composite in and out, SDi in and out, HD- SDI in and out.. S-video would also be nice. Is there a Kona card that can do this or am I into a lot of converters? I still use my Sony 1800and occaisionally 3/4″ archive tapes and even some vhs from time to time. Then I ‘ll have a commercial shot on Varicam or Cine Alta. I need to be able to deal with them all.
    Michael
    Herb Sevush replied 20 years, 1 month ago 4 Members · 3 Replies
  • Walter Biscardi
    July 26, 2006 at 11:39 pm
    [Michael Brassert] “I have been happy with my Cinewave but it is time to move on. I need analog component in and out, composite in and out, SDi in and out, HD- SDI in and out.. S-video would also be nice.”
    I ran the CineWave for three years and what you want is the combination of a Kona card and the Io LA. We have two Kona 2 systems and one Kona 3 system along with an Io LA.
    The LA gives you full analog input / output including S-Video. The Konas give you full SD and HD SDI along with Component output.
    Which Kona you require depends on your machine and your editing requirements. The LH and Kona 2 are for PCI-X machines. LHe and Kona 3 for PCIe machines.
    LH / LHe give you Analog Inputs along with HD to SD down-convert only.
    Kona 2 gives you digial inputs only along with Component HD / SD output. You also get SD to HD Up-convert and HD to SD Downconvert.
    Kona 3 gives you everything as the Kona 2 with the addition of HD Cross Convert. 720 to 1080 or 1080 to 720.
    Kona is the best choice to move from a CineWave workflow as it even contains a control panel somewhat similar to the CineWave panel.
    Walter Biscardi, Jr.
    HD Editorial for Food Network’s “Good Eats”
  • Adam Vincent
    July 28, 2006 at 9:45 pm
    Hey Walter,
    With a Kona 2 and an IO LA, would you be able to capture HD-SDI video only from the Kona 2 and the audio analog from the IO LA; from the same HD deck simultaneously? The reason I ask is, the HDCAMs we shoot with have an “emphasis” noise reduction feature, that basically boosts the treble on the camera, then the deck de-empasizes on the way out by the same amount (analog outputs). With embeded audio or AES/EBU, the de-emphasis does not happen, so you get treble/hissy audio, unless you use the analog outputs of the deck. I was able to accomplish this easily with the Cinewave system.
    I have turned this feature off on our camera, but older footeage or footage shot by our other division may still have “emphasis” on it.
    Adam Vincent, Alabama Public Television
    Dual 2 GHz G5 PCI-X 2 G RAM OS X 10.3.4
    Pinnacle Cinewave with Pro A & D, Pro HD BOBs, Cinewave 4.6
    ATTO UL4D
    Medea RTRX 1.3 TB stripped with ATTO express stripe
    UL4D in slot 4, Cinewave card in slot 2
    FCP 4.5
    Quicktime 6.5.2
  • Herb Sevush
    August 1, 2006 at 3:31 pm
    You might want to look at the BlackMagic Design Multi-Bridge. Unlike the Kona 3 it can handle both analog component and digital — both SD-SDI and HD-SDI. While it down-converts HD to SD on the fly it does not have the Kona 3’s ability to up-convert SD to HD and cross convert 1080 to 720 on the fly. But if you don’t need those features it might be your answer.
    Herb Sevush
    Zebra Productions
