Activity › Forums › AJA Video Systems › Kona and the Animatio Codec
Posted by Erik Lindahl on November 10, 2005 at 9:48 pmIs there any way of getting FCP5 and a Kona LS under Tiger to output the animation codec?
Regards
ErikMisha Aranyshev replied 20 years, 10 months ago 7 Members · 8 Replies -
Gary Adcock
November 10, 2005 at 9:59 pm[Erik Lindahl] “Is there any way of getting FCP5 and a Kona LS under Tiger to output the animation codec?”
Download the Kona TV app we about at IBC it will playout Animation codec files directly from all aja products.
Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA -
Gary Adcock
November 10, 2005 at 10:11 pm[gary adcock] “Download the Kona TV app we about at IBC”
that would be what “we talked about”
sorry operator error.
Gary Adcock
Studio37
Chicago, IL USA -
Aja Sales department
November 11, 2005 at 7:17 pmHi Erik-
There is a minor bug in KONA TV v1.1.1 with the Animation codec. The fix is to simply go to the “Display” menu, and pull down to RGBA output. KONA TV should then output RGBA Animation files correctly.
Thank you,
AJA Video Systems
(530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
David Battistella
November 11, 2005 at 9:36 pmDoes it support h264 or non standard size moves yet?
David
Erik Lindahl
November 11, 2005 at 11:42 pmYeah, when I choose RGBA today it actually worked. It didn’t do it just after I had installed the card (might have been a bad Animation file?) I just got a bunch of garbage on the videomonitor then.
Is it possible to playback Animation-codec in FCP?
Also, eventhough I’m breaking-away from the subject, will we ever see output from DVDSP through the KONA (or is this up to Apple to fix)?
Chris Poisson
November 14, 2005 at 2:05 pmErik,
Yes, you can use Animation in FCP, you can even do an easy setup for it so you will not have to render. Doub’t that Kona can help see DVDSP on a monitor, that’s Apple’s problem.
Have a wonderful day.
Misha Aranyshev
November 18, 2005 at 11:46 amHow about Animation with alpha or any other RGBA in Uncompressed 8-bit FCP timeline in RT?
