Activity › Forums › Apple Final Cut Pro Legacy › Kona and Io playing together.
  • Kona and Io playing together.
    Posted by David Rowan on April 25, 2008 at 7:04 pm
    A couple of weeks ago we got some nice new toys, some Quad-cores with Kona 3 cards in them. Very nice.
    Now I need to input from some consumer gear, so I hooked up my old Io, plugged in the VHS, loaded up the Io drivers and voila! Nothing.
    When I switch inputs in Final Cut I can see that they change on the Io front panel, but I just don’t see anything in the Record Tool window.
    In the Io control panel it says that there is a video input, but when I switch to FCP the Io controls go inactive and it says there is no video detected.
    I’m sure its just some little switch I have forgotten, but does anyone have some tips? By all accounts there should be no conflicts with the Kona.
    FCP 6.0.3 MacPro Quad 3.2 w 10GB RAM
    DWR
    Bob Flood replied 18 years, 5 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    April 25, 2008 at 7:08 pm
    Are you using the io easy setups form within FCP?
  • Bob Flood
    April 25, 2008 at 10:54 pm
    Dave
    I am still using a g5 and a dual cors intel, but its always squirrely trying to get my ioLA running with my kona card. I have to switch on the io, plug it into the firewire bus, make sure there is notheing else on the firewire bus, make sure i have video going into the io, then restart my computer, not just fcp. When i get fcp open, i have to make sure all my AV settings reflect the IO, not the kona. Then it usually works.
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
