Activity Forums Apple Final Cut Pro Legacy Kona and Decklink on same system
  • Kona and Decklink on same system
    Posted by Chris Anderson on June 19, 2008 at 4:49 am
    Would this work?
    For my new Mac Pro/FCP system I was thinking about buying the new Black Magic Decklink HD Extreme for capture and monitoring and when funds permit I would buy the Kona 3 and still use the Decklink for analog capture.
    Right now I use beta, DV, HDV and P2 DVCPRO HD 720p 23.98. The hardware conversion and cross conversion is why I would later go to the Kona 3.
    For now I just need analog conversion and monitoring so I figure the decklink is only a few hundred more then buying an analog to SDI converter later to go along with the Kona 3.
    I’m just not sure if the two play well together on the same system.
    I also currently own the HDLink
    Chris
    Rafael Amador replied 18 years, 2 months ago 4 Members · 6 Replies
  • Sean Oneil
    June 19, 2008 at 5:38 am
    [Chris Anderson] “Right now I use beta, DV, HDV and P2 DVCPRO HD 720p 23.98”
    Do any of these decks have SD analog input? Why don’t you just do that and use Firewire capture while you save up for a Kona 3 plus a Blackmagic analog to SDI Mini-converter.
    I think cramming two cards in the same system is a bad idea and your chances of finding someone who’s tried it will be slim. Also, available PCIe slots are like gold. You don’t want to waste one.
    Sean
  • Jeremy Garchow
    June 19, 2008 at 6:11 am
    [Sean ONeil] “I think cramming two cards in the same system is a bad idea and your chances of finding someone who’s tried it will be slim.”
    And it simply won’t work. The drivers will conflict.
  • Rafael Amador
    June 19, 2008 at 8:23 am
    As Shane sad it won’t work.
    You can not have the drivers of he two of them installed at the same time.
    Rafael
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Rafael Amador
    June 19, 2008 at 8:26 am
    Sorry, a lapsus.
    I meant Jeremy, no Shane.
    Rafael
    JVC DTV-17″
  • Jeremy Garchow
    June 19, 2008 at 2:31 pm
    [Rafael Amador] “I meant Jeremy, no Shane. “
    🙂 Honored to be in the same company as Shane.
    Jeremy
  • Rafael Amador
    June 19, 2008 at 5:59 pm
    You really are. And in the top:-)
    Jeremy, please have a look to my humble web site: nagavision@nagavideo.com
    Critics and suggestions are welcomed.
    Rafael
    http://www.nagavideo.com
