Activity Forums Adobe Premiere Pro Kona 3G question
  • Kona 3G question
    Posted by Chris Borjis on June 6, 2013 at 10:06 pm
    I have an opportunity to get a Kona3G for a great price.
    I won’t have access to an AES to Analog audio adapter for awhile.
    This one doesn’t have the breakout box, so I can’t use the analog
    audio out on that. My mixer console does not have AES inputs. (in this suite)
    Is it possible to use the MAC audio line output to monitor the
    editing in CS6? Will it be out of sync?
    Chris Borjis replied 13 years, 3 months ago 2 Members · 2 Replies
  • Tim Vaughan
    June 7, 2013 at 10:41 am
    Yes, you can use the audio line out to monitor audio and output the 3 to a monitor. I did this for years. Obviously you’d want the audio and monitor the be off the same deck, but sometimes you just have to make things work. I think you can even get the break out box for pretty cheap now anyway, so if/when the time comes, just upgrade. The Kona 3 works fine and if you have everything set up properly, there shouldn’t be any lag.
    Tim
    Apple XRAID, XServe, 2008 2×3 GHz Quad-Core MacPro, Macbook Pro, XSAN, Dell Studio xps PC’s
    FCP Studio (7), AVID Media Composer, Adobe Production Premium, Maxon Cinema 4d, AJA Kona 3, Flanders Scientific Monitors, Panasonic HPX250’s, Kessler Crane, Glidecam…..
    Beer fridge fully loaded.
  • Chris Borjis
    June 7, 2013 at 4:06 pm
    Thanks Tim. I will be getting a converter, just not immediately.
