Activity › Forums › AJA Video Systems › Kona 3g & Final cut 7.0.3 with 2k project
  • Kona 3g & Final cut 7.0.3 with 2k project
    Posted by Javier Sanchez on May 7, 2011 at 10:41 pm
    Hi all,
    I’m doing a project on 2K resolution on final cut but having trouble with monitoring:
    I set the final cut to aja 2048 1556 23,98 and when i set the SDI3 monitoring to display image i have 2 problems, on stop i see it squeeze to fit 1920×1080 jvc monitor and on play y see the image croped by downside.
    Thats with all my 2k material on FCP3 (DPX, proress, ….)
    Aja Sales department replied 15 years, 4 months ago 3 Members · 5 Replies
  • Aja Sales department
    May 9, 2011 at 5:21 pm
    To view 2K material on a 1920×1080 monitor, you will need to use the 2K Crop feature in the AJA Control Panel application. You will also need to select 2K as a geometry in the Video Setup or Setup tab of the AJA Control Panel application.
    You can find detailed information regarding 2K workflows in the AJA KONA operation manual. You can also feel free to contact AJA Technical Support for additional assistance via phone or email.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • Javier Sanchez
    May 9, 2011 at 5:59 pm
    I’ve tried to contact but no answer from AJA, i have check the 2k geometrie, set the 2k crop.
    But still same error, image on FCP3 croped on monitoring SDI…
    Regards
    Javier Sanchez
  • Rodolfo Davidson
    May 9, 2011 at 7:49 pm
    Aja Sales: I have the same problem using the final cut pro 7 video playback, im trying to output in my 1920×1080 monitor some dpx files 2k (2048×1556) but I cant get the correct preview, I have the Aja Kona 3 and the display error is the same that Javier Sanchez described to you. when I hit play the video automaticaly gets crop by the half like modifying the position in Y space. the settings of AJa control panel and the FCP sequence are the same.
    May 9, 2011 at 8:23 pm
    The 2K Crop feature is, as the name implies, a way to view 2K material on an HD monitor, but with some cropping of the image.
    Information for contacting AJA Technical Support can be found here:
    https://www.aja.com/support/contact-support.php
    Perhaps your previous phone or email message was simply not received. If so, we apologize for the inconvenience. You may consider contacting them again.
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
    May 9, 2011 at 9:10 pm
    Please contact AJA Technical Support for assistance if you need help using the 2K Crop feature.
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
