Activity › Forums › AJA Video Systems › Kona 3 vs Kona LHI
  • Kona 3 vs Kona LHI
    Posted by Chad Tingle on December 28, 2009 at 5:10 pm
    I am in the market for an upgrade, and I’ve narrowed it down to the Kona 3 and it’s little brother the Kona LHI. I know the Kona 3 provides some key advantages over the LHI such as Single link 4:22, Dual link 4:44 and 2k. They both up, down, and cross convert in 10 bit, so are there any other advantages to spending the extra money on the Kona 3.
    Matthew Causon replied 16 years, 9 months ago 2 Members · 2 Replies
  • Matthew Causon
    December 30, 2009 at 2:23 am
    Hello Chad
    Other than Red workflow that really comes under the 2k banner, the Kona 3 has 16 channels of embedded audio vs the Lhi’s 8 channels.
    https://www.aja.com/pdf/support/AJA_whitepaper_Red_workflow.pdf
    The Kona 3 also has 2 SDI connections, the LHi only one (though the LHi does have HDMI, 3G and analog, so a different spec set):
    https://www.aja.com/pdf/KONA_Line09.pdf
    Otherwise you have it pretty covered.
    Best regards
    Matty Causon
    Phosphor
    EMEA Business Management for AJA Video Systems Inc.
  • Matthew Causon
    December 30, 2009 at 2:31 am
    Ahh let me correct and update:
    Kona 3 has Red workflow (really comes under the 2k banner):
    The Kona 3 also has 2 SDI connections, the LHi only one (though the LHi does have HDMI, 3G and analog i/o, so a different spec set)
    Kona 3 has 10-bit HD/SD video + key output
    Kona 3 Internal HD/SD hardware based Downstream Keyer
    Best regards
    Matty Causon
    Phosphor
