Activity › Forums › Apple Final Cut Pro Legacy › Kona 3 vs IOhd
  • Posted by Dave Martin on December 26, 2007 at 5:26 pm
    Hi guys
    I’ve read and read and re-read the threads but my question is…If I have a Mac Pro with 8 gigs of ram and I don’t need to go portable…are there any other very compelling reasons to get an IOhd compared to a Kona 3?
    Thanks so much…
    Martin
    – MacPro – Quad Core – 4 gig Ram
    -MacBook Pro – 2.16GHz Intel Core Duo – 2 gig Ram
    -FCP Studio 5.1.4 – QT 7 – OSX 10 – Firmtek Sata Raid- G-raid dv drive
    Christopher Wright replied 18 years, 9 months ago 5 Members · 6 Replies
  • Chris Borjis
    December 26, 2007 at 5:31 pm
    If you don’t need portability or macbook use and you have a macpro, I can’t think of any reason to get the IO HD.
    If you need portability, the ability to edit from a notebook, or capture in ProRes HD on a G5 system, then its ideally suited.
    I’ll be getting one later this year, because I need all of that capability.
  • Dave Martin
    December 26, 2007 at 5:45 pm
    Thanks for the reply Chris
    I should also mention that I do have an AJA IO standard def to connect beta sp and other gear…
    Martin
  • Jerry Hofmann
    December 26, 2007 at 7:30 pm
    The Kona 3 has more capability than the Io, however the Io is more or less future proof because it doesn’t rely on a specific sort of card slot. Doesn’t capture uncompressed HD formats, but transcodes them to ProRes instead. It also will lift the CPU in your Mac from having to decode the ProRes for monitoring and layback to tape… but again doesn’t capture to an uncompressed HD format. Ya never know when Apple may make the current Kona 3 not work in their future Mac Pro’s… but if you keep your computer for a while, the Kona would amortize out most likely…. tough call unless you MUST have uncompressed HD files.
    Jerry
  • Dave Martin
    December 26, 2007 at 9:40 pm
    Thanks very much for the replies…
    From what I understand, not too many people actually go uncompressed anymore and especially now with ProRes. If I get the Kona 3 and use my IO standard def, I’ll save $1000 which I can put into a better monitor…
    Thanks guys!
    Martin
  • Tom Meegan
    December 27, 2007 at 11:05 am
    Dave,
    Unless you need the extra functionality of the Kona 3, consider the Kona LHe.
    Here is the comparison page:
    https://www.aja.com/html/products_macintosh_kona.html
    Tom
  • Christopher Wright
    December 27, 2007 at 7:49 pm
    Very interesting! I didn’t know the LH and LHe were capable of doing Prores!
