Activity › Forums › AJA Video Systems › Kona 3 Video Playback for DV
  • Kona 3 Video Playback for DV
    Posted by Ed Kulzer on April 21, 2012 at 4:45 am
    Evening COW— Looking to tap some knowledge.
    12-Core Mac Pro ( 2 x 2.93 GHz) wi/ 128GB RAM
    I’m running FCP 7.0.3 with the AJA Kona 3 & BOB, monitoring with the Flanders LM-2461W.
    The Kona Video Playback settings all seem to be 720 x 486; D1—- while the client’s footage & sequence are 720 x 480; DV.
    When I port the sequence over to Color for the grade, the sequence & material play just fine on the Flanders monitor— but in the FCP timeline, no dice. No Video playback.
    Any suggestions on what the proper A/V Settings & Video Playback should be?
    I’ve had the sequence set to
    720 x 480 NTSC DV (3:2)
    NTSC – CCIR 601
    29.97
    Apple ProRes (HQ)
    The AJA Kona Control Panel’s set to 525i for Primary & Secondary and it’s an SDI feed, which, again, works just fine with this material when inside of Color. Just not within FCP.
    Am I missing a Kona Easy Setup?
    Thanks in advance.
    David Cabestany replied 14 years, 5 months ago 3 Members · 2 Replies
  • Doug Beal
    April 23, 2012 at 3:02 pm
    set easy setup to AJA Kona3 NTSC 8bit to DV
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • David Cabestany
    April 24, 2012 at 9:11 pm
    Sorry for deviating from the original question, but I thought Mac Pros could only take 96gb when running Mac OS? How did you manage to have the system see the whole 128gb?
