Activity Forums AJA Video Systems Kona 3 – Video Output problem
  • Kona 3 – Video Output problem
    Posted by Jonny Hal on January 8, 2011 at 11:56 pm
    I can’t seem to get any output from my Kona 3 card — just a test pattern.
    Usually, when I switch between the FCP and any other app, I would notice a flip from my FCP edit to the default test pattern (set in the AJA) tool.
    Now, there’s no flip and the only thing I get is a test pattern or whatever I set as the Default Output in the AJA tool.
    I trashed my FCP plist
    I created an Easy Setup 8-bit uncompressed NTSC project
    None of these work.
    I’m going out of the Kona 3 – thru the breakout box — component beta into a Sony 40 XBR.
    Any help would be appreciated.
    Jonny Hal replied 15 years, 8 months ago 2 Members · 2 Replies
  • John Pale
    January 9, 2011 at 12:04 am
    Uninstall and re-install your kona drivers
  • Jonny Hal
    January 9, 2011 at 12:09 am
    duh – my output frames were set to none.
    eek.
