Activity Forums AJA Video Systems Kona 3 test signal problem
  • Kona 3 test signal problem
    Posted by Neil Patience on May 14, 2014 at 4:23 pm
    Hi All
    I have a Kona 3 card with a K3 breakout box. For some reason I cannot change the test pattern. I can select all the options but just not change the test pattern.
    I am using software version 10.5.1 and everything else seems to work. I have re-installed the Kona drivers a couple of times and re-installed FCP 7.03
    This has not been an issue until now, it has worked flawlessly for years. My OS is 10.7.5.
    It was working fine using this configuration until now. One thing I have noticed is that if I change the test signal then open FCP so it “grabs” the Kona card.
    Once I return to test patterns it has changed. Otherwise I can select any pattern just nothing changes unless I dip in and out of FCP.
    Any thoughts ?
    Thanks in advance
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 or MC V 7 with Symphony option. FCP7.03 Color, DaVinci Resolve, Media creation and conversion. Adobe Encore DVD & BluRay creation and authoring.
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 or MC v7 with Symphony option FCP7
    7TB raid 5 fibre storage.
    Mark Spano replied 12 years, 3 months ago 2 Members · 2 Replies
  • Mark Spano
    May 19, 2014 at 7:35 pm
    if I remember correctly, this problem used to exhibit itself when you attempted to change this value using a non-Administrator level account. Maybe that’s it. Otherwise, I would still point to something permissions based.
  • Neil Patience
    June 1, 2014 at 7:43 pm
    Thanks for the reply – will certainly check that out. I am pretty sure there is only the admin user set up on the machine but will investigate further.
    best wishes
    Neil
