Activity › Forums › AJA Video Systems › Kona 3/ IO LA set up advice
Posted by Jim on March 18, 2006 at 3:30 pmI have both the AJA IO LA and the Kona 3 attached to my Dual Core Quad 2.5, with a Panasonic 17
Bob Zelin replied 20 years, 6 months ago 2 Members · 3 Replies -
Bob Zelin
March 18, 2006 at 4:56 pmREPLIES BELOW –
The main reason for going with the Kona 3 as opposed to the LHe was the real-time up-conversion from SD to HD.
REPLY – In my opinion, you should have bought the AJA I/O, and not the I/O LA
becuase there ain’t no SDI output on the I/O LA, and that is how you feed the Kona 3.As I understand it from the K3 Op manual I can output SD component video out of the card to feed my Beta deck.(?) However, if I want to get analog audio out of the K3 (box) I will need a D/A converter (M Audio
Bob Zelin
March 19, 2006 at 3:01 pmREPLIES below –
As far as I can tell (pg 14) in the Kona Op manual they refer to the component output as the Analog Monitor Output. That is why I posed the question.
REPLY – this is an analog monitoring output. What this means is that if you have a SDI or HDSDI in/out situation, and you want to monitor what you are going, instead of tying up one of the HDSDI outputs (and having to buy a converter), AJA wonderfully provides you with a “free” CAV output to feed an analog component monitor, or a more modern LCD or Plasma with CAV inputs, so it can feed a HD Y Pb Pr analog signal to this monitor. Of course, you can feel free to use this output to feed your Beta VTR as well. It’s EXCELLENT full quality.
Re: K3 Box, I have the AJA K3 Box
