Activity Forums AJA Video Systems Kona 3 in slot 4?
  • Kona 3 in slot 4?
    Posted by Per Rönnecke on March 15, 2007 at 11:14 pm
    Hi!
    I have bought a MacPro with a Kona 3 card installed in slot 4. The installation notes delivered with the card says it should be in slot 3 for optimal performance.
    As far as I can see, I have no problem with the card. What could happened? Should I move it to slot 3?
    /Per
    Per Rönnecke replied 19 years, 5 months ago 3 Members · 3 Replies
  • Walter Biscardi
    March 16, 2007 at 1:16 am
    If AJA says Slot 3 is optimal, you should install it into Slot 3. Those folks spend a LOT of time testing all this stuff for us and I always follow their instructions to a T. Including the Expansion Slot utility.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Bob Zelin
    March 16, 2007 at 1:51 am
    the slots in the Mac Pro are dynamic, and the number of lanes can be changed with the apple Expansion Slot Utility. Slot 3 is the “safe” slot, as you can’t screw it up (by making it a 1 lane slot). Everything depends on where you put your storage host card (SATA, Fibre, or SCSI).
    Bob Zelin
  • Per Rönnecke
    March 16, 2007 at 7:09 am
    I’m just running Firewire 800 drives right now. Mayby I should move the card anyway.
    Per
