Activity Forums AJA Video Systems Kona 3 DPX workflow
  • Kona 3 DPX workflow
    Posted by Dado Valentic on June 16, 2009 at 7:08 pm
    I have just performed small test trying to figure out the best workflow.
    I took Quick Time AJA 10bit RGB and converted it to DPX using QTtoDPX tool. Then I used the same DPX to create AJA 10bit RGB full range with DPXtoQT and I got different resulting image.
    My original AJA RGB file looks different to AJA RGB created through roundtrip. My blacks and whites have shifted.
    Anyone has any clue why this might be happeneing?
    Dado Valentic
    colourst
    Chief Colourist http://www.mytherapy.tv
    Apple Certified Color Trainer
    Gary Adcock replied 17 years, 3 months ago 2 Members · 1 Reply
  • Gary Adcock
    June 17, 2009 at 10:01 am
    [Dado Valentic] “ook Quick Time AJA 10bit RGB and converted it to DPX using QTtoDPX tool. Then I used the same DPX to create AJA 10bit RGB full range with DPXtoQT and I got different resulting image. “
    that would be correct.
    one was full range (0-1024) vs one handling as SMPTE (64-940)
    There is also a know QT issue when handing off data between certain versions of AE and the Aja codec that requires that you remove the legacy “AJA 2Vuy” Codec from the QT library.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
