Activity › Forums › Apple Final Cut Pro Legacy › Kona 3 Codec on a Macbook Pro….
  • Kona 3 Codec on a Macbook Pro….
    Posted by Rajnesh Domalpalli on August 19, 2007 at 12:24 am
    Hello,
    I’m on a Macbook Pro : 2.16GHx Intel Core Duo, Mac OS 10.4.10 running Final Cut Studio 2
    and I tried installing Kona Codecs so that I could view and edit Kona 3 HD Files.
    I went to their Support Page for Kona 3, and downloaded the from the following link: AJA KONA Macintosh QuickTime
    Jeremy Garchow replied 19 years, 1 month ago 2 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    August 19, 2007 at 12:29 am
    Kona cards use the apple uncompressed codecs for their normal easy setups.
    If you open that movie in quicktime, what does it say under format when you hit apple-i
  • Rajnesh Domalpalli
    August 19, 2007 at 12:34 am
    Hi Jeremy,
    It says:
    AJA Kona 10-bit RGB Codec, 1920 x 1080, Millions
    Regards,
    Rajnesh
  • Jeremy Garchow
    August 19, 2007 at 12:46 am
    Restart your computer.
    August 19, 2007 at 12:53 am
    I just restarted the Computer… but I still get the Blank White Screen when I open the Quicktime File.
    What else could the problem be?
    Rajnesh
  • Jeremy Garchow
    August 19, 2007 at 12:56 am
    Are you sure it’s in the HardDrive > Library > Quicktime folder and not in your user directory?
    August 19, 2007 at 12:58 am
    Yes. I just checked again… and both those files are in the Macintosh HD/Library/Quicktime/ directory.
    Rajnesh
  • Jeremy Garchow
    August 19, 2007 at 1:11 am
    I just downloaded them and they appear to be PowerPC files.
    I am running a test, be back shortly with results.
  • Jeremy Garchow
    August 19, 2007 at 1:14 am
    Yeah, those are PowerPC. If you download and install the latest Kona3 drivers, the proper codec gets installed and you should be good.
    Jeremy
    August 19, 2007 at 1:24 am
    Hi Jeremy,
    Thank you so very, very much.
    It worked!
    Regards,
    Rajnesh
  • Jeremy Garchow
    August 19, 2007 at 1:26 am
    Glad you are up and running.
    Have fun!
