Activity Forums AJA Video Systems Kona 3 and Premiere Pro output
  • Kona 3 and Premiere Pro output
    Posted by Naveen Mallikarjuna on November 5, 2013 at 8:37 pm
    I’m running Premiere Pro CC 7.1.0 (141) on my Mac Pro OS X 10.7.5 with an AJA Kona 3. Kona drivers are 10.4.7.
    When I play a clip in Premiere, the video plays out of the Kona fine to an external monitor. The problem is with the audio, which “pops” a lot, or cuts out altogether.
    Anybody have a suggestion on how to fix this? Does 10.4.8 for the Kona drivers help, or is that just an update to work with OS X 10.9?
    Naveen
    Naveen Mallikarjuna replied 12 years, 3 months ago 2 Members · 2 Replies
  • Naveen Mallikarjuna
    November 13, 2013 at 7:52 pm
    I called AJA support. Forgot how good it is and that they take care things fast. Here was their solution, which worked perfectly:
    Audio Setting in Premiere Pro CC for Kona 3:
    1. Go to Premiere Pro > Preferences > Audio Hardware
    Use the following settings:
    Adobe Desktop Audio: Built-in Output
    Buffersize: 1024
    Map Output for: AJA Kona 3 – 0, Slot 3
    2. Go to Premiere Pro > Preferences > Playback
    Audio Device: AJA Kona 3 – 0, Slot 3
    Then, change the audio settings on the Mac
    1. Go to Mac OS X Preferences > Sound
    For both Output and Input, choose any device EXCEPT AJA Kona 3 (yes, counter intuitive)
    That’s it.
    Naveen
  • Michael Lansdell
    June 2, 2014 at 7:53 am
    Have you played out to tape from Premiere Pro CC using a Kona 3? I’ve a tight deadline project in it very soon and usually work in FCP/Symphony… Would be good to get a heads up on any potential issues!
    Best wishes,
    Michael
