Activity › Forums › AJA Video Systems › Kona 3 and After Effects CS5.5
  • Kona 3 and After Effects CS5.5
    Posted by Jef Huey on March 22, 2012 at 6:10 pm
    We just installed the AJA 10.1 drivers and the CS 5.5.3 plugins on a Win 7 64 bit system. It also runs MC 6.0.1 and the Kona card is happy with that software.
    The manual is pretty thin in regards to AE. I am wondering what I can really expect in usability. Right now I have a limited set of use options.
    For example, if I take quality down from full to anything else, I do not get realtime playback.
    The only Output setting that seems to work in the AJA Preview Settings is Output 8 bit RGBA 4:4:4:4. Anything else is non realtime.
    I can not get the Secondary Output to work at all.
    Does this sound right or is it pointing to a system problem of some type?
    Thanks for any insight.
    Jef
    Jeff Brown replied 14 years, 4 months ago 2 Members · 4 Replies
  • Jeff Brown
    March 26, 2012 at 2:18 pm
    Jef,
    My limited experience w/ AE on a Windows system is that for realtime playback:
    1) Do not use autoscale in the Kona output. Make sure it’s 1:1, i.e., if you are working at 1/2 rez, then you have a 1/2 size window on your SDI monitor.
    2) Match the computer size to the playback size. I don’t get realtime if I zoom the computer display to 50% while generating a “full” size preview. Computer display at 100% with full-size preview works well.
    And, do make sure you are rendering a preview, not using the space bar.
    I’m using the 10.0.1 x64 drivers and the 5.5.2 x64 plugins.
    -jeff
  • Jef Huey
    April 28, 2012 at 4:53 pm
    Sorry for slow response.
    Thanks for the suggestions – I will give them a try. Especially the “no autoscale” – I am pretty sure I have that enabled currently.
    Sure wish the document was better.
    Cheers,
    Jef
  • Jef Huey
    May 4, 2012 at 7:10 pm
    Hey Jeff (with 2 f’s 😉 )
    The “don’t use Auto Resize Image” suggestion was great.
    Thanks again!!
    Jef (with 1 f)
  • Jeff Brown
    May 7, 2012 at 12:51 pm
    From (ff) to (f): glad it helped!
