Activity Forums AJA Video Systems Kona 3 and After Effects 7.01
  • Kona 3 and After Effects 7.01
    Posted by Mark Maness on May 1, 2007 at 2:35 pm
    I have a question of how to see 1080i video from After Effects thru my Kona 3 card.
    When I select the option in the preferences – Video Preview, I get all of the settings that I thought were correct but when I close the preferences window and my screen updates, I get a small image in the center of my screen.
    I do know about the setting for Scale and Letterbox in the Video Preview preferences window. BUT… Is there a way to see it full resolution full screen as it is meant to be or is this an After Effects 7 issue?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    Mark Maness replied 19 years, 5 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    May 1, 2007 at 2:51 pm
    Open your Kona control panel, is anything down converting or anything like that?
    Jeremy
  • Walter Biscardi
    May 1, 2007 at 2:56 pm
    [Wayne Carey] “I do know about the setting for Scale and Letterbox in the Video Preview preferences window. BUT… Is there a way to see it full resolution full screen as it is meant to be or is this an After Effects 7 issue?”
    It works fine here, in fact I just did some 1080i animations yesterday in AE 7. Must be some conflict between the Kona Control Panel and your AE settings.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Mark Maness
    May 2, 2007 at 3:36 pm
    Can you give me your settings and I’ll check to see if something is wrong. I can’t seem to find anything wrong with my settings. BUT I’m sure that I am overlooking something.
    Wayne Carey
    Schazam Productions
