Activity Forums AJA Video Systems kona 3 analog output only showing single frame
  • kona 3 analog output only showing single frame
    Posted by Ben Turner on July 31, 2007 at 1:16 pm
    I read the manuals for FCP and kona 3. I finally got the analog output to work in FCP plus the test patterns and such, but FCP won’t play in real time. The only frame that shows up is once you hit pause or stop in the timeline.
    I switched the view to “all frames” in FCP, to no success.
    In the manual, the Setup tab of the Kona control panel has a check box for “FCP 5.1 compatible” I don’t even have that option in my updated software. Could that be why playback isn’t working right? I am running 5.1.4 and am outputting 720p60 to a non broadcast panasonic pro plasma.
    Thanks for everyone’s help really. I meant no disrespect in that last thread. I learn so much on this website, but should have researched your Kona threads before my purchase.
    Ben
    Ben Turner replied 19 years, 1 month ago 2 Members · 2 Replies
