Activity Forums AJA Video Systems Kona 2 Question
  • Kona 2 Question
    Posted by Scott Sutter on August 31, 2006 at 12:51 pm
    For some reason i cant get my desktop to show up on my external monitor? on monday we had an editor in to work on a project and he had changed some setting to screw up my kona 2 output. It seems like the external monitor which is a sony standard def 9inch color monitor, is receiving a funky signal (possibly a 24p signal because the project the editor was working on was a 24p hi ef project). Before i had it set up that when i was not in final cut that my desktop would show up on the external monitor. Now the only time the signal is correct is when i go into final cut. I can kind of see my desktop on the external monitor but like i said the signal it is receiving is incorrect. any input would be much appreciated.
    System setup:
    Mac g5 dual 2ghz with 2.5gb memory
    running 10.4.6 operating system
    Final cut pro 5.0.4
    Aja kona 2 card with the k-box
    external monitor hooked up with composite y/c
    external sata 2 raid with 2tb of space
    Scott Sutter
    Editor
    Resolution Digital Studios
    http://www.rdschicago.com
    Scott Sutter replied 20 years ago 3 Members · 3 Replies
  • Bob Zelin
    August 31, 2006 at 11:47 pm
    the selection is in the Kona Control panel – I forgot where.
    It’s easy to find – just poke around in the kona control panel.
    Bob zelin
  • Walter Biscardi
    August 31, 2006 at 11:50 pm
    Kona Control Panel > Control Tab.
    I usually leave this set to black.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Scott Sutter
    September 1, 2006 at 12:39 pm
    thanks for the replies..i figured out that the 2nd monitor output under system preferences was set to a frequency of 23.9 mhz, therefore sending a high def signal to a standard def monitor. I had to hook up the big sony hd monitor to get this figured out. Thanks though guys
