Activity Forums AJA Video Systems Kona 2 i/o Firewire question
  • Kona 2 i/o Firewire question
    Posted by Mark Tyson on July 29, 2005 at 6:57 pm
    I use an i/o now and I’m anticipating adding a Kona 2 card. My question centers around using the i/o as a conversion device. Obviously the G5 operates the i/o control panel through the firewire port, but once I launch FCP, does that disable the i/o as a stand alone device? Do I just use Kona setups in FCP and the i/o is just a firewire device out on it’s own accesed through the control panel? Just trying to figure all the audio and video routing. Hope this is clear.
    TIA
    Mark Tyson
    Mark Tyson replied 21 years, 1 month ago 2 Members · 2 Replies
  • Fred Connors jr.
    July 30, 2005 at 11:42 pm
    …Obviously the G5 operates the i/o control panel through the firewire port, but once I launch FCP, does that disable the i/o as a stand alone device?
    You operate the control panel and you select the I/O device. You disable or enable.
    ….Do I just use Kona setups in FCP and the i/o is just a firewire device out on it’s own accesed through the control panel?
    Kona Setups for Kona I/O, iO setups for iO I/O. ( I always wanted to say that)
    FCP A/V setup determines the Input and output devices. Then if an Kona2 is the Input or Output device then the Kona Contril Panle takes over from there.
    ….Just trying to figure all the audio and video routing.
    Lots of options
    Hope this is clear.
    Fred
  • Mark Tyson
    July 31, 2005 at 3:29 am
    Fred;
    Thanks. Guess I better order the Kona. Sounds like the Kona & i/o work together very elegantly.
    Mark Tyson
