Activity Forums AJA Video Systems Kona 2 Install
  • Kona 2 Install
    Posted by Editor182 on May 6, 2006 at 12:20 am
    Going from a Cinewave card to a Kona 2 Card. How hard is the install? I’m pretty handy with a computer. What is the reccomended slot?
    Walter Biscardi replied 20 years ago 2 Members · 1 Reply
  • Walter Biscardi
    May 6, 2006 at 2:35 am
    First make sure you have a PCI-X machine, that’s the older models like the original Dual 2.0’s that we run here. If you run SCSI or Fibre Storage, put that card into Slot 4 and the Kona 2 either into Slot 3 or 4. I run mine in Slot 3.
    If you have a newer PCIe machine, then you will require the Kona 3 card.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
