Activity Forums AJA Video Systems Kona 2 Component levels
  • Kona 2 Component levels
    Posted by Ken Ecker on September 15, 2006 at 6:07 pm
    Hello,
    Dual 2.7, 8 G RAM, Kona2, Breakout Box. I’m using component video to monitor to a Sony PVML5. All looks nice in the 525i29.97 footage (DV), but when looking at Varicam footage DVCProHD 720p59.94 (24fps), it looks noticeably darker, in fact, all HD timelines are dark. The gamma and coloursync (I think that’s the term, not at my setup right now), are set to auto, and moving them to rec 709 doesn’t make a difference. I’ve used the monitor in other situations and it was fine so it must be the card or it’s settings.
    Many thanks,
    Ken
    David Battistella replied 20 years ago 3 Members · 3 Replies
  • Bob Zelin
    September 15, 2006 at 7:30 pm
    without a scope, I can’t give you an honest answer, but much SD footage has setup (black levels) at 7.5 IRE, and that same material (or all SDI and HD-SDI footage) has black set for 0 IRE (no setup level) – so the SAME material looks DARKER when you observe it via a SDI or HD-SDI path. This has tormented people long before the AVID was invented.
    Bob Zelin
  • David Battistella
    September 17, 2006 at 9:12 pm
    When you move to the HD color space then you must take into account that you are cutting in Zero Black land. Therefore you do need to set the monitor up with HD 720P bars from final cut. Bob is right, there is a gamma shift between SD and HD. Maybe you can save a couple of user set-ups on the monitor and flip between them.
    David
    Peace and Love 🙂
  • David Battistella
    September 17, 2006 at 9:14 pm
    Found this great word document on it here:
    https://www.google.com/search?client=safari&rls=en&q=HD+color+bar+setup&ie=UTF-8&oe=UTF-8
    David
    Peace and Love 🙂
