Activity Forums AJA Video Systems kona 2 board shifts on input
  • kona 2 board shifts on input
    Posted by Frank Ruggiero on May 31, 2005 at 5:44 pm
    Hello everyone,
    I know there are probably so many factors that can effect a Kona 2 board’s performance. if anyone has any info on this issue however, I would greatly appreciate it.
    It seems that my Kona board is shifting my video down a line or two on input to the Macintosh. I know that in the Kona control panel there is an area in which you can shift video horizontally or vertically. It does not seem to do anything to resolve my issue.
    Does anyone know what may be causing the video to shift on input? Could this be sometype of reference issue? Unfortunately, I am an After Effects artist, and my engineers have not had success in resolving my issue.
    I am using Kona 2 with the 1.1 driver set, a dual 2 gig G5 with a HUGE SCSI array and 3 gigs of ram. The OS is 10.3.9.
    Any info would be great. Thank you.
    Frank Ruggiero
    Frank Ruggiero replied 21 years, 3 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    May 31, 2005 at 8:57 pm
    Latest driver is 1.1.1. Might try installing that.
    Jerry
  • Frank Ruggiero
    May 31, 2005 at 9:05 pm
    Hey Jerry, Thanks again for your help.
    Do you know if driver 1.1.1 is acceptable when you are using Panther and FCP 4.5HD? I thought that 1.1.1 was released for users with Tiger/FCP5.
    Any info is appreciated, Thanks.
    Frank R.
  • Jeremy Garchow
    June 1, 2005 at 12:06 am
    Yes, you can run 1.1.1 on Panther/ FCP 4.5. I am running it now.
  • Frank Ruggiero
    June 1, 2005 at 1:10 am
    Hey guys,
    Thanks for the info. That was the problem!
    -Frank R.
