Activity Forums AJA Video Systems Kona 2 Audio
  • Kona 2 Audio
    Posted by Michael Ruiz on August 18, 2005 at 2:26 am
    Im purchasing the Kona 2 card and need
    to know if the Analog Outputs on the KBOX
    will be good enough to mix audio or will
    I need a DA converter.
    Thanks for the help
    Mr2005
    Berenger Capmany replied 21 years ago 3 Members · 4 Replies
  • Jeremy Garchow
    August 18, 2005 at 3:35 am
    What exactly do you mean by mix audio?
    The analog outputs are rca which you will have to adapt to get to XLR or 1/4″ for a mixer to deal with the levels. I have found this method to be more noisy than getting a d/a (I use a flying cow from M-Audio).
    Other people might tell you differently, but this is my experience.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Michael Ruiz
    August 18, 2005 at 5:22 am
    Jeremy
    Thanks for responding. I wanted to know if the sound quality coming from the RCA
    is good or if it was noisy or untrue to AES Digital. I will need to go with a DA converter
    from what it sounds like.
    I cant get a Flying Cow, they are out of production right now!!
    any suggestions to a good low cost source
    Michael
  • Jeremy Garchow
    August 18, 2005 at 3:59 pm
    https://www.sweetwater.com/store/detail/SuperDAC2496/
    It’s strictly a D/A and not an A/D like the flying cow, but it does what you need at a good price.
  • Berenger Capmany
    August 24, 2005 at 10:08 pm
    Hello..
    have you experienced video delay problems?
    I also have a Kona2+KBox… analg audio on the RCA is in sync with the digital video on both SDI outs (HD and SD) but Analog video (either composite and component) have a delay.
    So I can’t use the RCA audio to feed a downconverted analog video.
    It happen teh same converting the AES to analog?
    puting and audio D/A converter delays also the audio and at the end both analog signals are on sync again?
    I’m working on PAL..
    thanks in advance…
