Activity Forums AJA Video Systems Kona 2 and Logic Pro 7
  • Kona 2 and Logic Pro 7
    Posted by Wolfgang on December 9, 2005 at 11:39 pm
    Has anyone tried to output a surround mix from Logic Pro using the embedded HD-SDI channels of the Kona 2 to a Panasonic 1200a deck?
    I am using a Tascam 1884 to monitor my mix and for the control surface. It’s working great so far in Logic but I want to go out with the Kona 2 when I am done mixing.
    Is this possible? Does anyone know if the Kona 2 card will work with Logic Pro 7? I don’t have the card yet but should have it in a week or so.
    Wolf
    Ron Thompson replied 20 years, 9 months ago 2 Members · 3 Replies
  • Ron Thompson
    December 10, 2005 at 12:10 am
    I can’t answer your whole question…but with the KonaLH, Logic7 runs great.
    I can take an XML or OMF from FCP and do my mixing with Logic…including video preview on my monitors or NTSC monitor via Kona.
    I use the Mackie Control surface with FCP and Logic. No problems…very responsive…little to no setup in either program. Obviously you get more functionality out of the Mackie once you fire up Logic. Audio is clean out of the Kona.
    So I’m sure you can output a surround mix as long as the 1200A accepts all of the channels. Better answered by someone who has it.
    As you probably know already you can setup your surround outputs in the Logic preferences.
    Ron
  • Wolfgang
    December 10, 2005 at 8:10 pm
    Are you bringing the video clip into Logic as a QT file? Do you have to export it separately to work with in Logic?
    I was planning on using machine control and viewing the video straight off the master on the 1200A. That is how I was working with Pro Tools. The timeline was locked to the time code on the master and everything moved together.
    Thanks for the info!
    Wolf
  • Ron Thompson
    December 11, 2005 at 3:35 pm
    [Wolf] “Are you bringing the video clip into Logic as a QT file? Do you have to export it separately to work with in Logic?”
    Yes, and Yes. There is a “import movie” command in one of the drop down menus. (Not in front of the computer right now, but I think its in the Windows menu).
    You can set Logic’s timeline to SMPTE and sync the video to the timeline.
    It works automatically, but you can set offsets if needed too.
    Again, the video chase is pretty accurate when using a control surface like the Mackie.
    Ron
