Activity › Forums › AJA Video Systems › Kona 2 and DVCPRO 50
Posted by Paul Nevison on May 17, 2005 at 1:44 pmhey there
looking into the kona 2 and heard that it doesnt support the dvcpro 50 codec…true or a vicious rumour? thanks
Walter Biscardi replied 21 years, 4 months ago 2 Members · 3 Replies -
Walter Biscardi
May 17, 2005 at 2:07 pm[nevo] “true or a vicious rumour? thanks”
Vicious rumor. I’m just checking all my Easy Setups and there are multiple AJA Kona 2 DVCPro 50 easy setups, including the ability to capture 8 or 10 bit sources to the DVCPro 50 codec.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Paul Nevison
May 17, 2005 at 2:34 pmhey walter,
good to see you are a head cow over here now….i’m looking into the kona 2 to replace our cinewave – feel like im following you down the technology road!!!
out of interest in your HD work how have you found the cinema display? is it up to the job? its not a crt hd monitor and it never will be but is there any usefulness beyond the apple hype?
system 1 G5DP 2.0 / 2.0G RAM / OS 10.3.8 / QT 6.5.2 / FCP HD 4.5 / CineWave 4.7 / Cinewave RT Pro/ Pro Digital Plus & Pro Analogue BOB
Walter Biscardi
May 17, 2005 at 5:20 pm[nevo] “out of interest in your HD work how have you found the cinema display? is it up to the job? its not a crt hd monitor and it never will be but is there any usefulness beyond the apple hype?”
I don’t use it as an HD monitor, just for computer / FCP work. I have a Sony PVM20L5/1 that I use for HD and then a consumer HD Plasma screen, 42″ for a larger display. I don’t really have any plans for the Cinema Display to be used for HD right now. If I really want a high quality display, I’ll probably go with a pro plasma display from panasonic at some point.
Switching to the Kona 2 will be the easiest decision you’ll make coming from a CineWave based system.
