Activity › Forums › AJA Video Systems › Kona 2 – 1.2 driver – small vertical stretch on reverse-play
  • Kona 2 – 1.2 driver – small vertical stretch on reverse-play
    Posted by Bill Portune on February 9, 2006 at 8:05 pm
    Can someone confirm or deny this for me – I’m getting a small vertical stretch of the image when I reverse-play a shot (J key – DV50 codec). On pause and forward-play the image pops back. It isn’t a big deal, but it’s a bothersome new anomaly with the 1.2 driver. (preferences already been trashed…)
    Also I’ve found that I have to shift newly captured footage 2 pixels down to get it to exactly match previously captured footage (SDI HDCAM-SD)…
    Bill Portune
    The Chesapeake Group
    G5 DP 2G, 10.4.4, QT 7.0.4, 1.5GB RAM, FCP 5.0.4, Io (2.0), Kona2 (1.2), UL4D, Huge U320R
    Bill Portune replied 20 years, 7 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    February 10, 2006 at 10:12 am
    Are you rendered?
  • Jeremy Garchow
    February 10, 2006 at 10:32 am
    Are you rendered?
  • Bill Portune
    February 10, 2006 at 5:15 pm
    It does it on all footage all the time (DV50 captured: rendered, RT or no effects), in the canvas or viewer – Even does it in Kona TV with DV50 captured footage. (This is happening on my video monitor not on my G5 monitor.)
    Transcoded to uncompressed – doesn’t do it.
    Bill Portune
  • Bill Portune
    February 10, 2006 at 5:26 pm
    Interestingly, if I switch to 10-bit output the image just shifts up on reverse-play (no stretch), while on 8-bit output the bottom of the frame stays but the image stretches vertically the same amount. If I match the shift with the motion tab it appears to be about 6 pixels – 480 vs. 486 ?
    Bill Portune
  • Ron Thompson
    February 12, 2006 at 11:36 pm
    I can confirm the stretch. I edit a show in DV50 (SDX900/24p) and when I reverse play, I see the stretch. Not a big deal, but you’re not alone.
    Ron
  • Bill Portune
    February 13, 2006 at 1:14 am
    Thanks, hopefully this will be addressed shortly with a driver update…
    Bill Portune
