Activity Forums AJA Video Systems Kona 1.1.1 FCP 5.0 and Audio?
  • Kona 1.1.1 FCP 5.0 and Audio?
    Posted by Fred Connors jr. on May 25, 2005 at 3:11 pm
    Hello fellow grazers…
    We have found ourselves with time to upgrade so we took the plunge.
    OS 10.3.9, QuickTime 7, FCP 5.0, KONA-2 with 1.1.1 software and current firmware, (not using Xraids).
    All has gone very well except for an audio issue with newly captured clips.
    The audio of all new clips captured in SD via SDI or AES, is off by two frames. The audio is two frames ahead of the video.
    Is anyone else seeing/hearing this?
    Fred
    Fred Connors jr. replied 21 years, 3 months ago 2 Members · 3 Replies
  • Fred Connors jr.
    May 25, 2005 at 5:43 pm
    Here is how to reproduce/fix the problem.
    I have tested this in SD only.
    In the Kona Control Panel, set the video reference sync to Ref In, set the Control to Macintosh Desktop, and set the audio in for AES or SDI.
    Select the clip(s) to capture and go into Batch Capture. Before the capture begins the desktop will appear on the KONA video. (This is not what I would expect as the proper behavior.) When the in point of the clip occurs the KONA video switches to the incomming video signal. The sync does not have time to lock up the audio and the result is out of sync for the clip. SDI audio will only result in a 2 frame audio offset, AES audio will have the 2 frame offset and a 1.5 second audio drop out at the begining of the captured clip.
    The work around is the set the KONA Control Panel video reference to Video In prior to Batch capture.
    Fred
  • Keicol
    June 7, 2005 at 6:27 am
    Yes, now what?
  • Fred Connors jr.
    June 9, 2005 at 8:32 pm
    Now What What?
