Activity Forums Broadcasting Knox RS 16X16 HB “re-setting”
  • Knox RS 16X16 HB “re-setting”
    Posted by Joe Piazzo on December 3, 2010 at 5:49 pm
    Hi all,
    Have a knox RS 16 HB switcher that intermittently re-sets itself (briefly seems to turn on and off). The settings / routes return as previously set, but it causes all 3 broadcast channels to go black for a second.
    I am thinking the power supply is going. My partner here suggested that the Knox has a button battery that might be going bad – but I don’t think it would then save the settings.
    The problem actually began as an occasional re-set when you entered a manual swith on the front panel. Now it is doing it on the hour or so, then stops for a while – then continues. Disconnecting serial control has no affect.
    Ken Karns replied 14 years, 1 month ago 3 Members · 2 Replies
  • Bob Zelin
    December 4, 2010 at 3:57 pm
    perhaps it’s time for a new router.
    This is an analog router, correct ? You can get a Kramer 16×16 for about 3 grand, that will be more reliable than the Knox.
    If you were SDI (which I guess you are not), you could choose from the wonderful Blackmagic or AJA family, for the same price.
    Bob ZElin
  • Ken Karns
    July 31, 2012 at 4:49 am
    We have found the Knox switchers to be very reliable.Also,The Knox technical service I have found to be great.Even if your 16X16 is out of warrenty,they have a great staff thats always willing to help.Contact them at https://www.knoxvideo.com/ and click on tech support.
    Hope you get some help with this problem
    Ken Karns
    NCIRradio
