Activity Forums Adobe After Effects KNOLL LIGHT problem
  • KNOLL LIGHT problem
    Posted by Ron Dejoseph on March 8, 2007 at 5:51 pm
    i’m trying to make flash bulb effects on a comp. i’m using adjustment layers with KNOLL light effx for my flashes.
    i can’t use multiple layers that overlap, the effect doesn’t show up!
    am i missing something here?
    David Bogie replied 19 years, 6 months ago 3 Members · 5 Replies
  • Jim Wilcox
    March 8, 2007 at 6:01 pm
    Transfer Mode?
  • Ron Dejoseph
    March 8, 2007 at 6:16 pm
    normal…tried them all though…no difference….
  • Jim Wilcox
    March 8, 2007 at 6:20 pm
    I’m looking at Knoll Light Factory LE and if I have a flare applied to a solid layer and set transfer mode to SCREEN we’re good to go. You could try Unmult or Xmult as well if you have them.
  • Ron Dejoseph
    March 8, 2007 at 7:03 pm
    thanks!!!!!
  • David Bogie
    March 9, 2007 at 6:07 pm
    theanvel.com
    This one is called Free NAB Class 7.0 After Effects Projects for download – Creating an Alpha Channel for the Lens Flare Effects
    https://theanvel.com/free_aeps_detail.php?aeps=80
    bogiesan
