Activity Forums Adobe After Effects Knoll Light Factory Render Error
  • Knoll Light Factory Render Error
    Posted by Jackson Redshaw on February 7, 2013 at 4:01 am
    Hey,
    I just rendered out a 3 minutes composition and I have some lens flares using ‘Knoll Light Factory EZ’ in the AAE file it looks perfect, in a RAM preview it looks perfect but in a final render it looks like this:
    Instead of this:
    EDIT: I discovered the problem is when I change the Resolution to be rendered from Full to Half (or third) … Is there any way I can work around this? Otherwise I am up for a very lengthy render time!
    Jackson Redshaw
    http://www.youtube.com/MITLRproductions
    Daniel Potuznik replied 12 years, 4 months ago 4 Members · 4 Replies
  • Joseph W. bourke
    February 7, 2013 at 4:52 am
    Well, now that you have most of it rendered, maybe you could just pull the rendered piece into AE, and overlay the lens flare, then render that at full rez. Should be a quick render.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Jackson Redshaw
    February 7, 2013 at 5:08 am
    There is also a few other things I should fix, is there no way to render Half Resolution with Knoll Light Factory EZ?
    Jackson Redshaw
  • Vishesh Arora
    February 7, 2013 at 8:30 am
    Jackson
    Rendering at Half Resolution will not give you good results.
    Otherwise I am up for a very lengthy render time.
    The reason is you are using CC Vector Blur.
    You can try using other Blur Effects like Directional Blur to reduce the render time.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Daniel Potuznik
    May 7, 2014 at 9:21 am
    i found why it’s so slow, you need to uncheck the motion blur for the layer contains the light factory
    hope it’s help other 🙂
    Have nice day
    Daniel
