Activity › Forums › Adobe After Effects › knoll light factory question
  • knoll light factory question
    Posted by Matthew Mcnulty on August 27, 2009 at 8:24 pm
    have some nice cloud footage, want to add a sun or bright star to it… easy enough… new solid, knoll light factory EZ… but getting the star to interact with the clouds not so easy… cloud layer has no alpha for obscuration, so tried using shift channel, not so good… any techniques or work flows would be sweet thanks!
    Matthew Mcnulty replied 17 years, 1 month ago 4 Members · 4 Replies
  • Michael Szalapski
    August 27, 2009 at 11:39 pm
    Hooray for keyframing by hand!
    Or you could try a duplicate of the layer and some kind of color key.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Todd Kopriva
    August 28, 2009 at 5:04 am
    Something like this?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Scott Novasic
    August 28, 2009 at 5:46 am
    I would render out the clouds layer in a separate comp. Pull the color out of it, and use the levels
    to crank up the contrast some. Use this layer as an obscuration layer using the alpha. Double up the greyscale layer on top of itself and use the layer mode ‘stencil alpha’ to create the alpha. OR just use the one layer and use its luminance.
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Matthew Mcnulty
    August 28, 2009 at 4:47 pm
    seems to stick on the “Flare Center” verbiage… i get this waring
    after effect warning:class effect has no property or method named ‘flare center’
    i replaced with light source location and the flare disappeared
    any suggestions
