Activity Forums Adobe After Effects Knoll Light Factory problem – appears in previews / does not render?
  • Knoll Light Factory problem – appears in previews / does not render?
    Posted by Tim West on November 23, 2009 at 9:49 am
    I’m having a few problems with teh Knoll Light factory plug-in – the effect is showing up perfectly in my previews but whenever I try to render it appears so faint it is hardly visible.
    I haven’t changed anything in my project between rendering successfully and now having this problem – does anyone have any idea how to fix this?
    T.
    Mark Walczak replied 16 years, 6 months ago 3 Members · 2 Replies
  • Gary Hazen
    November 23, 2009 at 1:13 pm
    What are your preview settings? Previewing at low res can make some flares appear much bolder than they are at full res. Set your viewer and/or RAM preview settings to full res to get an accurate picture of what the rendered output will look like.
  • Mark Walczak
    March 25, 2010 at 5:21 pm
    Just wanted to add my two cents.
    I just experienced this problem, and my issues lied in two ares: the preview resolution, and my obscuration layers. Fortunately, my obscuration layers were not critical to my end result, so disabling them allowed me to render accurately. Once I upped my preview resolution to “Full” I was then able to view my work properly and render accordingly.
    Thanks for your wisdom, Gary!
    https://vimeo.com/explosivegraffix
