Activity › Forums › Adobe After Effects › knoll light factory LF stripe prob
  • knoll light factory LF stripe prob
    Posted by Matt Linden on July 6, 2008 at 3:17 pm
    hi , i got a problem with the KLF – LF stripe ,when i apply it i get alot of small dots(like pixel errors)all over my composition and i really cant figure out if its a bug or if i can turn this off somehow.
    hope some1 can help me, i have tryed google it ect but havent found any matches to my problem,so i decide to get pro help here 😀
    sry if its a newbie problem,but im stuck in my project due to this 🙁
    im using AE cs3 and KLF 2.5.2 (trail ver.)and os : xp
    best regards matt :>
    Matt Linden replied 18 years, 2 months ago 2 Members · 4 Replies
  • Chris Wright
    July 6, 2008 at 10:03 pm
    set layer quality to best and turn off aspect correction ratio view.
  • Matt Linden
    July 7, 2008 at 1:48 am
    hmm didnt help :/ still looks like theres small particles in different colors on my background.
    it only happens when i apply knoll light :s
    should i take a screenshot or any other ideers how to fix it. 🙁
  • Chris Wright
    July 7, 2008 at 2:38 am
    does it render out correctly? if it does, its just opengl preview, disable that. other things to try is 32 bpc in file->project or even if your preview is 50% size, that would make it look bad. I’m sure I’ll think of more in the future, but try to remove possibilities with older project files and/or renders.
  • Matt Linden
    July 7, 2008 at 12:03 pm
    yes the dots is still there when i render out.if i make a new comp,apply black solid and then knoll light (any of em)the colored dots appear :s hmm when i turn on 16 bpc it help a bit but its still useless imo 🙁
    here’s 2 screenshots (just uploadet em to imageshack,hope its ok)
    1.normal 100% https://img139.imageshack.us/img139/3438/lfstripeio6.jpg
    2.zoomed.200% https://img391.imageshack.us/img391/4166/lfstripex2wl6.jpg
    this is how it looks just with black solid + LF_stripe.. is it somthing in my settings that causes this or ?
