Activity Forums Maxon Cinema 4D Knife Tool Snap Settings
  • Knife Tool Snap Settings
    Posted by Petcov Petru on December 21, 2011 at 1:28 pm
    Sorry if this is a newbie question but I cannot get it right not at all.
    I don’t get the right results with the Knife tool.
    Like you see in the picture I want just the line pointed by the green arrow,don’t need those 2 lines pointed with the red arrows.But everytime I make a cut 1 or 2 more lines(cuts) are created.How can I make a cut with just 1 line from one point to the other.
    I 99% sure it’s about the Snap settings but I don’t know how to set it to obtain what I want.
    So if you can help me I would much appreciate it.Thanks
    Petcov Petru replied 14 years, 8 months ago 2 Members · 5 Replies
  • Brian Jones
    December 21, 2011 at 4:44 pm
    check off Create N-Gons in the knife tool options
  • Petcov Petru
    December 21, 2011 at 9:27 pm
    Thank you I tried that – it cuts still the same.
  • Petcov Petru
    December 21, 2011 at 10:43 pm
    I observe that on most objects it doesn’t work,it works just on Platonic object.
    And also I observe that these adjacent lines are in fact other color,something like green.By the way I tried to cut with Point tool and in the Knife’s tool Line mode.
    Those green lines,if I tried to select them with Live Selection tool and Edge tool I can’t.
    So what these green lines are?
  • Brian Jones
    December 21, 2011 at 11:14 pm
    when you create an n-gon you are really creating poly that acts like one poly but is really more than one if the poly has more than 4 vertices. You must have “N-Gon Lines” checked off in the Viewport/Filter settings if you Configure one (or all) of the viewports and so you are seeing the hidden lines which make up the n-gon.
  • Petcov Petru
    December 22, 2011 at 9:14 am
    Yeah that’s it…Thank you very much and sorry for this newbie question.
