Forums AJA Video Systems KL Box 60 Pin Cable Connector
  • KL Box 60 Pin Cable Connector
  • John McKenney
    December 6, 2011 at 2:54 am
    Seasons Greetings,
    Does anyone know if the breakout box cable with the 60 pin connectors that go from the KONA KL box to the Kona KLH card is proprietary, or can I use this 60 pin LFH Male to 60 Pin LFH Male cable, that cablestogo.com has for sale? https://www.cablestogo.com/product.asp?cat_id=3533&sku=15334
    John McKenney
  • AJA Sales Department
    December 6, 2011 at 10:27 pm
    AJA breakout boxes are supplied with interconnect cables; if you need a spare cable for some reason, your AJA reseller can order one for you. If you have a damaged KL Box cable, you can contact AJA directly for an RMA replacement cable.
    If you need assistance, don’t hesitate to contact your AJA reseller or AJA Technical Support.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    [email protected]
  • Stephen Albrow
    July 3, 2015 at 9:47 am
    Hello. Did you solve your problem through AJA and/or did you successfully use the very reasonably priced CISCO compatible crossover cable from cablestogo? I have acquired a breakout box but lack a cable. Thanks. Best wishes. Stephen
Viewing 1 - 3 of 3 posts
Log in to reply.
