Activity › Forums › Storage & Archiving › KiPro Media Card Copy
  • Brie Clayton
    February 19, 2025 at 10:46 pm
    Hello Ken! Via AJA, I’ve been advised the following regarding your question:
    Unfortunately there is not a direct way of transferring data between 2 PAK media drives on the KPU-12G.
    The reason is only one slot with PAK media is active (mounted) at any one time.
    There is however a indirect way to transfer media, here are the steps to transfer clips from PAK 1 to PAK 2:
    1. Use <SLOT> button to make sure PAK 1 is active (LED on PAK drive is active).
    2. Using the Web UI Menu:
    1. Go to Media -> Media State and set to DATA LAN (mode)
    2. Go to Playlist-> All Clips
    3. Checkbox all the clips to transfer
    4. Click on Download (located just above the list of recorded clips)
  • Press <SLOT> button on UI or KPU-12G to dismount PAK 1
  • Press <SLOT> button again to mount PAK 2
  • Using the Web UI Menu:
    1. Go to Playlist-> All Clips
    2. Click on Upload (located just above the list of recorded clips).
    3. Browse and select downloaded clips from step 2 and click upload.
  • This completes the transfer.
  • AJA also offers a PAK DOCK PRO: Enterprise Level Flash Memory SSD Recording Media
    It can be used to transfer from PAK media externally onto the active PAK media drive of the KPU-12G while in LAN Mode.
    Hope this helps!
