Activity › Forums › AJA Video Systems › KiPro and Epic Issue
  • KiPro and Epic Issue
    Posted by Rodrigo Allendes-fernandez on March 18, 2013 at 10:41 pm
    Hi there.
    Last week was working with Red Epic, and choose some settings of Ki Pro:
    6.1 Genlock: INPUT
    8.0 TC In: SDI RP188
    8.3 Arm Recording: TC/Rec Key
    13.1 Camera Data: RED EPIC
    Camera: TC FreeRun
    Some issues which I had:
    – When shutting down and restart for batery swapt, some times, at the first record, KiPro suddenly stops record with WARNING: DROPPED FRAMES message. Maybe Genlock and Camera Data should be deactivate before shuuting down and reactivate after restart.
    – Deactivate Camera Data, Shutting down and then restart… Ki Pro goes crazy recording clips, because Arm Recording is TC set and Camera is TC FreeRun. Ok, logical, but weird when KiPro records 1 second clip, and then oher, and then other, and never could stop, neither pressing Stop button.
    – In configuration referred to above, the Rec Button seems to not work properly. When hit Rec button, Record doesn’t start. So, I must deactivate Camera Data to record i.e. a rehearsal.
    Can anyone guide or explain me why this issues happens?
    Best Regards
    Rodrigo Allendes-Fernandez
    Video Assist Operator
    Rodrigo Allendes-fernandez replied 13 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
