Activity Forums Adobe After Effects Kinetic Typography text with Nulls
  • Kinetic Typography text with Nulls
    Posted by Nik Read on March 27, 2014 at 3:26 pm
    Hi there
    I’m creating a Kinetic Typography piece using a null layer to move around the screen i.e. zoom into and out of the text (this is how it was taught to me on Lynda.com) however the problem is when I need to zoom right into text. Even though I have the ‘continuously rasterise’ button on, the text looks awful. If I scale the text up normally using the ‘S’ key then no problem, as long as the button is checked.
    Please help, I realise it’s probably a basic thing but it’s wasting my day here very quickly!!! 🙁
    Many thanks in advance.
    Nik
    Nik Read replied 12 years, 6 months ago 2 Members · 4 Replies
  • John Cuevas
    March 27, 2014 at 3:33 pm
    You would need to post a screen grab for me to be sure, but when you are “zooming” into the text, are you zooming up the composition, “cntl” + “+”, to sizes like 200% and 400%. When you scale up the comp, you are just zooming into the 1920×1080 pixels and it will look aliased. So make sure your comp is at 100% scale, full resolution.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Nik Read
    March 27, 2014 at 3:40 pm
    Hi Johnny,
    I’m putting all the layers in 3d and using the Z anchor point to zoom into the text – is this not correct?
    thanks for answering so quickly,
    Nik
  • John Cuevas
    March 27, 2014 at 4:16 pm
    Just did a test, 3D text, attached to null, zooming using null anchor point and it looks fine. As you can see in this example.
    7294_zoomingintotext.aep.zip
    Either post a screen grab, so we can see your settings, or post the project(without assets) so it can be quickly analyzed.
    Thinkck.com
  • Nik Read
    March 27, 2014 at 4:24 pm
    Hi Johnny
    i think i have the solution… I was using a camera parented to the null so when I used the Z anchor to zoom in it was increasing the comp size massively.
    In reference to your signature, I think I’ve learned about 693 wrong ways to do Kinetic Typography today 🙂
    Thanks so much for taking the time to help me, have a great day.
    regards
    Nik
