Activity Forums VEGAS Pro Killer 6.0c surround bug – HELP!
  • Killer 6.0c surround bug – HELP!
    Posted by Stephen Van vuuren on February 11, 2006 at 12:29 am
    Okay, after trying in vain to post on Sony forums and exchanging a series of unhelpful emails with Sony Support, I’m going to try once more before rebuilding 4 film projects from scratch.
    First, I have tried the usual – uninstalling, reinstalling Vegas, drivers etc. Second, I have been successfully creating surround projects since version 5. I have a eMu Emulator X setup audio.
    THE PROBLEM:
    Most of the surround projects I created in 5 are now not working in 6.0C. What occurs is that all 6 channels go the LR of the sound card. Vegas Mixer indicates correct surround channel playback but eMu mixer only show LR.
    Here’s where it gets weird. Close project, start a new surround project without changing anything and surround works correctly, every time. Furthermore, if you add a new track in the problem project and attempt any surround panning, you get the same problem, only LR output. ‘ve verified and re-verified project settings are identical. Also, I have a couple of simple surround projects created in 5 that are working correctly.
    There must be some data in VEG file that is corrupted or someone is mapping output incorrectly. Otherwise, the problem would happen with both files. I also confirmed that mix-down to stereo was not engaged, though curiously, engaging it on and off in the problem projects changes the sound slightly, although both are LR only.
    Any help or insight would be much appreciated.
    __________________
    stephen v2
    http://www.stephenv2.com
    Stephen Van vuuren replied 20 years, 6 months ago 1 Member · 1 Reply
  • Stephen Van vuuren
    February 11, 2006 at 2:39 am
    Solved by a tech on Sony audio forum. Master bus routing had revertred all output to first two ASIO channels despite project settings and mixer meters indicated correct surround setup.
