Activity › Forums › AJA Video Systems › Ki-Pro vs. HDcam
  • Ki-Pro vs. HDcam
    Posted by Barry Ehrmann on September 13, 2010 at 6:16 pm
    Hi All,
    I produce concert videos and am considering recording a multi-camera shoot (using Sony 1500’s), with Ki-Pro recorders instead of HDcam, which is what I normally use.
    Does anyone have experience with using the Ki-Pro’s with full HD cameras, under extreme lighting conditions? I realize on paper that ProResHQ is a better format than HDcam (10bit vs. 8bit, 220mbps vs 150mbps, 4:2:2 vs. 3:1:1, 1920 vs.1440), but am concerned that at the end of the day, it is still a compressed codec where I might get artifacting in heavy strobe lighting, pyro, or just hot lighting.
    Any experience or expertise would be appreciated!
    Barry
    Gary Snyder replied 16 years ago 3 Members · 2 Replies
  • Jeremy Garchow
    September 13, 2010 at 7:48 pm
    Whatever comes out of your camera is how it is recorded. You will get the step-up up in sampling, color space and raster, but if you’re over exposed in camera, the KiPro will record that signal.
    The compression from ProResHQ will be less than tape. You will get ‘better’ images right out of the box, but any gross errors aren’t ‘fixed’ by recording to the Ki.
    So, as long as you shoot correctly, you will get gorgeous images out of the KiPro, and be ready to edit virtually instantaneously.
    Jeremy
  • Gary Snyder
    September 14, 2010 at 12:59 am
    We currently have 10 – Sony HDC-1500 chains and use the
    KiPro – in addition to P2 and the Cinedeck for very high quality .
    All work very well,..
    send me an e-mail off-line, I’d like to hear more about your project.
    Tnx… Gary Snyder
    GaryS@clarkmedia.com
    Gary C. Snyder
    President / Engineer
    Clark Media
    610-694-9800
    HD rentals in New York and Philadelphia
    Panasonic, Sony and Arri Alexa
