Activity Forums AJA Video Systems Ki pro not reading input
  • Ki pro not reading input
    Posted by Lynn Cual on June 30, 2011 at 10:01 pm
    Have a windows pc into a scan converter using the rgb setting. Ki Pro still not reading video input. Any suggestions?
    James Lowenthal replied 15 years ago 3 Members · 2 Replies
  • Aja Sales department
    June 30, 2011 at 11:15 pm
    You should try contacting AJA Technical Support via phone or email for assistance with this.
    Please be aware that a scan converter may be outputting a format and frame rate that the Ki Pro does not understand natively. Additionally, you mention RGB; the full size Ki Pro product only supports component analog Y/Pb/Pr input, not RGB.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • James Lowenthal
    August 18, 2011 at 7:17 pm
    We just tried going out of a folsom presentation pro, component out, 1024 x 768 59.97hz directly into the component input on the kipro and can not get a signal. We take that same cable right into a monitor and it’s good to go, so the cable is good and the output is there.
    We’ve tried all of the different syncs on the input selection of the kipro component input to no avail.
    Suggestions?
