Activity › Forums › AJA Video Systems › ki pro drive not recognized by iMac w 10.9.2
  • ki pro drive not recognized by iMac w 10.9.2
    Posted by Craig Alan on March 15, 2014 at 2:04 am
    800 to 800 firewire cable with or without power supply to ki pro drive. Two different computers. Same interconnect with portable g-drive is recognized. Ki pro drive is fine plays back footage in Ki Pro.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
    Craig Alan replied 12 years, 6 months ago 2 Members · 4 Replies
  • Gary Adcock
    March 15, 2014 at 3:35 pm
    [Craig Alan] “800 to 800 firewire cable with or without power supply to ki pro drive”
    The KiPro drives need to have external power when used with the Apple TB> firewire adaptor.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    Follow my blog at https://www.garyadcock.com
    Or follow me on Twitter
    @garyadcock
  • Craig Alan
    March 15, 2014 at 5:05 pm
    I gave it external power. I was not using the thunderbolt port but 800 to 800 firewire cable. I brought the drive home with me and it worked on my Mac Pro also with 10.9.2. So it’s not the OS. Now the iMacs at work were using the thunderbolt port with a pegasus raid. Just the same, I’ve had no problems connecting other firewire devices to the same IMacs. Under ‘about this mac’ system report>firewire it reported an “unknown” device was hooked up but it did not appear in disc utility nor in the finder.
    KI-STOR250-RO Rev C
  • Gary Adcock
    March 15, 2014 at 11:14 pm
    [Craig Alan] “Under ‘about this mac’ system report>firewire it reported an “unknown” device was hooked up but it did not appear in disc utility nor in the finder.”
    Thanks for the update Craig
    Then it sounds as if the FW port has been damaged, you will be able to extract the files from the drive via ethernet when it is attached to the KiPro,
    gary adcock
    Studio37
    Chicago, IL
    @garyadcock
  • Craig Alan
    March 16, 2014 at 5:26 pm
    Well the port is not damaged on the iMac since the iMac works with other drives. And it is not damaged on drive since the drive worked on my Mac Pro at home. It also did not work on another iMac of the same vintage. So something is amiss but not sure what. Since it connected on the Mac Pro I copied the files to a portable drive. Nice to know I can also connect via ethernet. Did they ever add firewire support to the Ki Pro itself. There was talk of that a while back. Been a while since I updated anything.
