Activity Forums AJA Video Systems Ki Pro as a sound recorder?
  • Ki Pro as a sound recorder?
    Posted by John Mallidis on June 13, 2014 at 10:13 am
    Hi everybody.
    A year ago or more, I found online a tip on how to trick the AJA Ki Pro Mini to record sound only from a microphone connected to the XLR inputs WITHOUT a camera connected to it.
    I have used the Ki as a sound recorder and worked fine!
    Does someone knows how? I have spent hours to find again that post with the trick but had no luck 🙁
    John Mallidis
    Mike Cohen replied 12 years, 3 months ago 4 Members · 5 Replies
  • Mike Cohen
    June 16, 2014 at 8:44 pm
    you used to need video of some kind to go with the audio, however I would suspect that absent video you would just get a blue screen. On the PIX240, which is similar to the KiPro, if you remove a video signal while recording, you get a blue screen on playback but the recording continues without incident. Worth a try PRIOR to your shoot of course.
    Mike Cohen
  • John Mallidis
    June 17, 2014 at 6:03 am
    Hi Mike, thanks for your answer.
    The AJA Ki Pro Mini does not record unless it recognizes signal coming from SDI or HDMI input. There is a way to trick it – to fool the system and start recording only audio coming from XLR inputs. It is doable with a set of adjustments. I have tried for hours but can not remember the right combination! Urghhhh….
    I should have kept a note when I had found that post!
    John
  • Jeff Cronenberg
    June 17, 2014 at 11:05 am
    Try turning on the Video SG (item number 41.2 on the config menu) I believe that will allow you to record without a camera attached. I can’t be sure as I do not have one here with me, but I think that should work for you.
  • Kishan Vaghela
    June 17, 2014 at 1:17 pm
    We r using kipro more then year..we also use some time for record only audio..so i just ON Video SG 41.2…there is no need of any external Video Input..
  • John Mallidis
    June 18, 2014 at 10:40 pm
    The trick with VIDEO SG worked fine!
    Thanks to all,
    John
