Activity › Forums › Apple Final Cut Pro › Keywords Won´t Work
  • Keywords Won´t Work
    Posted by Nicolas J russo on October 20, 2016 at 4:07 pm
    Hi, I´m editing a Documentary on 10.2.3. When I´m at library level and do a search for a keyword that we have log AFTER we import the footage (Like “Rehearsal at the theater”) the software won´t give me any result. Even though I´m seeing the collection with that name. But when I do the search with words that FCP took from the Directories names (like DAY01, CANON, CAM01…) it gives me the results.
    Is there a way to turn on the keywords that you assign when you log the material in the search?
    I got to the UI when you click on the little magnifying glass, but got the same luck.
    Any insight would be great
    Brian Seegmiller replied 9 years, 11 months ago 4 Members · 16 Replies
  • 16 Replies
  • Noah Kadner
    October 20, 2016 at 11:42 pm
    Can you send a screen snapshot of your event please. Shift Apple 4.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Nicolas J russo
    October 26, 2016 at 2:34 pm
    Thanks Noah, the first image are the clips in the search windows. The second is the advanced search with all the keywords (spanish)
  • Brian Seegmiller
    October 26, 2016 at 4:59 pm
    What you need to do is choose the uncheck all and then check the keywords you want.
  • Nicolas J russo
    October 26, 2016 at 5:25 pm
    Thanks Brian for your help. I have seen tutorials where they assigned keywords while watching the footage and then they could find that footage by typing in the search bar. What you say about checking the keywords, it works but it´s a workaround… I was looking for a solution for the typing search. To look in a list of keywords, is not how it was design to work.
    Maybe there is a file that I can delete or something so FCP needs to reindex the files? I don´t know if someone has Avid experience but like erasing the database of the Avid MediaFiles directory…
    Thanks anyway for the feedback
  • Brian Seegmiller
    October 26, 2016 at 6:17 pm
    Unfortunately, you can only search keywords this way, or toggle the event down to see the keywords for that event. If I had that many keywords I would create folders to help organize your keywords. Do You have a link to the tutorial you saw?
  • Nicolas J russo
    October 26, 2016 at 6:32 pm
    Here is an excerpt of Lynda – Final Cut Pro X Guru Organizing Assets’. This guy logged the footage with the keyword DOLLY and when he is actually editing, he finds that footage by looking that word.
    https://we.tl/kq0Xz6O91F
  • Brian Seegmiller
    October 26, 2016 at 7:40 pm
    In his example he is searching names of clips and not keywords. He does have a keyword DOLLY but he is actually searching names of clips.
  • Nicolas J russo
    October 26, 2016 at 7:50 pm
    I didn´t realize that. So no way to look for the keywords made while logging.
    Is there a difference with the keywords that are made by FCP during the import? the keywords as the folders names and the tags that are created in finder? Because I can look for those and it works
  • Brian Seegmiller
    October 26, 2016 at 8:21 pm
    Keep in mind If you have an event selected your search will only search in that event. If you search a library it will search in that library. I am not sure about keywords as finder tags. I will need to try that.
  • Brian Seegmiller
    October 26, 2016 at 8:31 pm
    Kind of weird behavior in FCP X. Keywords from the finder seem to be searchable but keywords created in FCP X are not if you just type the word in the search field. But, if you have more than one word as your keyword the first word will get results but if you have two words or more and type all of them it will not get results.
