Activity Forums Apple Final Cut Pro Keyword Search
  • Keyword Search
    Posted by Geoff Addis on May 9, 2012 at 7:21 pm
    I must be doing something wrong, but I cannot see what!
    I’ve created Keyword Collections for each of several rooms and have sorted the clips into the appropriate collection and then have applied additional keywords to identify the type of shot etc. Now, when I do a search by inserting a keyword in the search window all I get is a blank result field; however, if I click on the search icon (magnifying glass) I get the search filter and then by adding KEYWORD to the search criteria I am able to do a search. Entering anything in the TEXT field results in the blank result field. Nothing ever appears in the TEXT field of the search window!
    Is this normal in 10.0.4 or am I missing atrick?
    TIA
    Geoff.
    Kevin Patrick replied 14 years, 4 months ago 4 Members · 5 Replies
  • Tom Wolsky
    May 9, 2012 at 8:25 pm
    Keywords aren’t text. Press Cmd-F. Click the + button in the upper right and select keywords. You can deselect them all and activate the ones you want to search for.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
  • Geoff Addis
    May 9, 2012 at 9:05 pm
    Thanks, Tom. I guessed that it must be something simple tyhat I had overlooked!
    Geoff
  • John Moffat
    May 10, 2012 at 5:49 am
    This is a bit of a gotcha as keywords are not searchable in the same way text is. As Tom pointed out keywords are only searchable via the tick boxes in the advance filter window which will become a very inefficient way of quickly looking for shots when you start having 20 or 50 or 100 different keyword.
    I think keywords are great for loose grouping of shots (Interview, B-roll, Scene, ‘Rooms’ etc – similar to the coloured labels in FCP7) but nothing beats adding a little text in the note field. Then you can properly use the filter in dialogue box. Smart collects are also a very powerfully tool to organise footage,
  • Geoff Addis
    May 10, 2012 at 9:03 am
    Yes, it was the fact that TEXT search does not include keywords that stumped me. A pity as it does slow things up. At least I now know that I wasn’t doing anything too stupid!
    Geoff
  • Kevin Patrick
    May 10, 2012 at 1:02 pm
    In case you had not seen this tip on new searching abilities.
    Make sure you watch all of the clip, at the end they cover the searching clip types as well.
    https://www.fcp.co/final-cut-pro/tutorials/822-using-the-new-meta-search-features-in-final-cut-pro-x?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+FCPdotCO+%28FCPdotCo+Main+RSS+Feed%29
